Altera Cyclone IV Internal Memory - ROM: 1-Port Problem
Adrian3
Newbie level 2
I have created a MIF file containing 100 x 16bit values. The values point to a colour palette which contains the RGB values for 10 colours.
In Quartus Prime Lite I have used the IP Catalogue to create a ROM: 1-Port file
My top Verilog HDL file references the ROM file which when compiled / simulated on the FPGA development board should produce a 10 coloured stripped square (10 x 10 pixels) on the attached monitor. However, all I get is a blue square.
Could you please help me with where my code is going wrong. After I compile the design the total memory bits states 4 / 423,936 ( < 1 % ), which I believe is not right for the size of the data I am trying to place in the ROM memory.
I have attached the files for my design (in .txt format). Please ignore the 640x480 file name references, it should actually be 800x600
  • Pal.txt
  • Spriterom.v.txt
  • VGA640x480.mif.txt
  • VGA640x480.v.txt
The spiterom module isn't referenced because variable address isn't driven in the design. Instead it must be connected to clk.
Accessing q as an array is also wrong. You get the memory value according to variable address back in variable q.
You'll notice that ROM value q is delayed relative to address.
The best way to check the operation of your design step-by-step is to use Modelsim.
Many, many thanks for the reply.
So my code;
Code dot - [expand]
8
9
10
11
12
reg [6:0] address;
reg clock;
wire [15:0] q;
Spriterom u1(
    address,
    clock,
    q);
initial clock=0;[/B]
Is this correct or should I be using "clk" instead of "clock".
During the
Code dot - [expand]
H_SCAN > HZSYNC+HBACK_PORCH
and
V_SCAN < VTSYNC+VBACK_PORCH+VACTIVE+1
is it possible to read the ROM during this period and output it via "red" , "green" and "blue".
I understand what you say about q. Would you be able to provide me with some code showing how to do it correctly please.
