Altera and Xilinx JTAG cable
gargamel_67
Newbie level 2
Newbie level 2
I'd like to know if Altera and Xilinx' JTAG cable are compatible?
I'd like to use an Altera JTAG cable to configure a Xilinx CPLD with Xilinx software. Is it possible?
Has anyone already done it ?
I have never tried @ltera cable on X*linx, but the task should be easy: Compare the documentation of the cables, and see if it fits.
Do not count on any compatibility due to software issues if the cable is anything but a plain passive (or with only simple drivers) serial or parallel port cable. USB version from @ltera propably wouldn't work.
@ltera has several different cables, so depending if you have MasterBlaster or BitBlaster or ByteBlaster, you might succeed.
See their web pages for documents about @ltera cables:
You got the link for X*linx cable earlier from drwho78 in this same forum...
I guess you might try to do a little homework with those data sheets, and see if the particular cable you plan to use is compatible with X*linx.
Good luck,
Ted
I have compared the Xilinx and @ltera parallel download cables awhile back. They are not interchangable. The parallel port pins used between the two cables are not the same. As for the other versions of download cables, they are definitely not interchangable
The two download cables are fairly simple to build. It should cost less than $20 in parts for the two cables.
