Nov 2, 2003 #1 M majnoon Full Member level 5 Joined Dec 11, 2002 Messages 281 Helped 36 Reputation 72 Reaction score 4 Trophy points 1,298 Activity points 1,623 Allegro 14.2 problem I recently experiencing problems with Allegro 14.2. When I try to start the software it gives a message: "Cannot open message file, env path is possibly set incorrectly. critical variables not set in the env file, ...." I have PCBENV folder and I copied env file into C:\Cadence\PSD_14.2\share\pcb\text but still gives the same message any idea?? It used to work poroperly. Thanks
Jan 31, 2004 #2 H HytekPro Newbie level 6 Joined Dec 13, 2002 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 166 In your case, I think the env file has problem. You can use the Notepad to open the env file and find out. It may have something not right in there. Keep in mind that, you can use the Notepad to edit the env file only NOT wordpad.
Feb 1, 2004 #3 A arcaphill Member level 5 Joined Dec 17, 2003 Messages 85 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 650 Re: Allegro 14.2 problem Do not move the PCBENV folder
Apr 7, 2004 #4 A arcaphill Member level 5 Joined Dec 17, 2003 Messages 85 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 650 Allegro 14.2 problem Move the env file to C:\, and try it again!
Jul 25, 2005 #5 A amjad Full Member level 5 Joined Dec 29, 2002 Messages 273 Helped 9 Reputation 18 Reaction score 5 Trophy points 1,298 Activity points 2,291 Re: Allegro 14.2 problem You should set the Home variable path of system's enironmental variable to the path where you have your pcbenv folder
