AIRCONDITION is not colling enough
donrigor
Junior Member level 2
AIRCONDITION
what are the reasons why airconditiioning unit doesn't give enough cool even it is raised iin its lowest temperature?
Re: AIRCONDITION
There could be lots of reasons ::
1) Air filter is chocked
2) Low Gas Level
3) Evaporator fins r chocked
4) Dirt in the Condenser fins
5) Fans r running at low speed
6) broken insulations on Suction & discharge lines
7) compressor performance has degrade
8) check the Thermostate is working fine (+ Electronic circuit)
9) check the relay that triggers the compressor motor is working fine.
10 never expose ur outdoor compressor unit directly to the sunlight use some shade (split type)
& many more . . .
AIRCONDITION
Excellent ....points to be noted. Guess you know better about AC. Keep it up Hameed.
AIRCONDITION
Right now I am having a new natural gas furnace (96% efficient) and a new air conditioner (very efficient) installed.
My old ones wasted a lot of energy and were worn out. My government is paying a high rebate for their high efficiency and I will save a lot of money on natural gas and electricity.
Re: AIRCONDITION
Excellent sir, thank you it helps a lot!
Re: AIRCONDITION
Its done Hameeds01 thanks again!
