buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 961
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,128
Hi
In agilent ADS momentum there are two ways to model a ground plane: slot_planes and strip_planes.
In slot_plane method the program only meshes the voids, like antipads and splits, while in strip_plane method it meshes the copper areas. The strip_plane method results in a lot more mesh cells in a simulation.
I would think that using strip planes would be more accurate to simulate the effect of an imperfect ground plane (like antipad fields) and return currents, since it meshes the plane itself.
Am I right or wrong?
What is the exact accuracy difference between the 2 methods? I know how the 2 methods are different in building the models (electric currents vs magnetic currents), but how do they correlate to measurements (the 2 types separately) in case of heaviliy antipad-ded ground planes?
Basically how does the slot_plane method model the return currents, when the path of those return currents is not part of the model?
