Advantage and Disadvantage of DTMF In Telephony
arbabar
Member level 2
Member level 2
Islamabad
HI what is the advantage and disadvantage of DTMF in Tone dialing?
what is it difference with the Latest ISDN?
DTMF isn't used with ISDN. ISDN relies on bytes which contain the encoded digit. Not many people use ISDN for phone calls these days, by the way
(some countries use it more).
Restricted to phone calls, there is no "advantage" or "disadvantage" of DTMF - there is no other way to get the signal to the phone company if you're
on an analog line.
For non-analog-phone-line use (POTS), then DTMF is archaic, since there are other more efficient encoding methods.
You are mixing apples and oranges. DTMF is used just for the transmission of the "dial" information from a telephone keypad to the central station. ISDN is a standard for digital transmission of voice, data, and video, etc.
