Chr's
Junior Member level 1
First of all, I found some old topic about the question regarding the noise simulation, like this one:
https://www.edaboard.com/threads/148584/
My question is about a process to generate a noise simulation without all these steps, because do it for the worst cases and typical it's quite boring and spend lot of time.
Regarding my filter, it's a Tow-Thomas with a current input and voltage output, central frequency at -1MHz.
I found a test bench which uses only one noise source and generate signal for I and Q automaticaly.
The attached drawing explains clearly (I beleive :smile
I don't find any cells (ideal, ahdl, veriloga, ...) to do this phase shiffter (a combiner) and the V2I. I'm trying with vcvs and ccvs but the phase is set by a time delay (not like AC paramter like in vdc,vsin,idc,isin,...) which change during the noise simulation (because the noise uses an AC simulation). I want a cell with a constant phase shift during the AC simulation. If someone has an idea to do these cells, he's welcome. :-D
I don't how this guy did it. :sad:
Thanks in advance.
Thanks in advance.
