[51] ADuC842 How to save ACC to EEPROM
hello_world
Newbie level 2
Newbie level 2
Hello,
I have project to do and it is completed in 90%. My problem is how to save ACC (0-9) to EEPROM.
CD-ROM contains example code how to use FlashEE, but my 52 saves something, but I don't know what :D
It's code for garage door using LCD display, engine not works but lecturer says that is not problem. It reads from FlashEE number of pages, if it's 1 goes to READFLASH else goes to START. On INC_L and INC# it's saves ACC in WRITEFLASH.
My code:
$MOD842                                 ; use 8052 predefined symbols
; definicja polaczenia lcd z uC
LCD_D4      EQU P2.1
LCD_D5      EQU P2.0
LCD_D6      EQU P2.3
LCD_D7      EQU P2.2
LCD_E       EQU P2.5
LCD_RW      EQU P2.4
LCD_RS      EQU P2.7
LCD_KEY     EQU P2.6
LCD_PORT    EQU P2
LCD_DATA    EQU 30h                     ; KOMORKA PAMIECI Z KToREJ BAJT WYSYLANY
                                        ; DO WYSWIETLACZA
BUTTON      EQU P3.2                    ; Przycisk INT0
READ     EQU    01h                     ; FlashEE command:  'read page'
WRITE    EQU    02h                     ; FlashEE command:  'write page'
VERIFY   EQU    04h                     ; FlashEE command:  'verify page'
ERASE    EQU    05h                     ; FlashEE command:  'erase page'
ERASEALL EQU    06h                     ; FlashEE command:  'erase all'
ORG  0000h
CALL LCD_INIT                           ; Inicjalizacja wyswietlacza LCD
; Zapisanie polskich znakow do CG RAM  -
MOV   LCD_DATA, #40h                    ; Ustawienie kursora na pierwszy
ACALL LCD_ROZKAZ                        ; znak pamieci CG RAM
MOV   DPTR, #TAB_3
CALL  CIAG_ZN                           ; Wyslanie do LCD ciagu znakow z
                                        ; z tablicy 3 do CG RAM o adresie
                                        ; podanym w DPTR konczacego sie 80h
MAIN:
	MOV   EADRH, #0                       ; set data FlashEE address to page 0
    MOV   EADRL, #0
READFLASH:
    MOV   ECON, #READ                    ; read current 4byte page of FlashEE
                                        ; into EDATA1,2,3,4
    MOV   A, EDATA4
    CJNE  A, #1, START                   ; if EDATA4 is 1, then page contains
                                        ; a valid ACC
                                        ;        => read EEPROM
                                        ; otherwise jump to START
READ_EE:
    CALL  READ1_L
    JMP   START
READ1_L:
	CLR   A
    MOV   DPL, A
    MOV   DPH, A                         ; clear DPTR
    MOV   DPP, A
    MOV   R6, #EDATA3
    MOV   A, #0
    CJNE  R6, #0, READ2_L
    MOV   LCD_DATA, #01h                ; czyszczenie ekranu
    ACALL LCD_ROZKAZ
    MOV   LCD_DATA, #80h                ; kursor na 1 linii
    ACALL LCD_ROZKAZ
    MOV   DPTR, #EDATA1_0
    CALL  CIAG_ZN
    CALL  DLY3
    RET
READ2_L:
    DEC   R6
    INC   ACC
    PUSH  ACC
    CALL  WAIT_D
    JMP   DEC_L
START:
    CLR   A
    MOV   A, #0
    CALL  RESET_L
WRITEFLASH:
    MOV   ECON, #ERASEALL                 ; clear all data FlashEE memory
    MOV   EADRH, #0
    MOV   EADRL, #0
WRITE_EE:
    CALL  WRITE1_L
    MOV   EDATA1, DPL                    ; place DPTR in EDATA1,2,3
    MOV   EDATA2, DPH
;    MOV   EDATA3, DPP
    MOV   EDATA4, #1                     ; put 1 in EDATA4 as identifier
    MOV   ECON, #WRITE                   ; write EDATA1-4 into pre-erased
                                        ; page of FlashEE data memory
    MOV   ECON, #VERIFY                  ; verify current page is same as
    MOV   A, ECON                        ; EDATA1-4.  If same, ECON=0.
    JNZ   WRITEFLASH                     ; if verify fails, jump to RECORD
    RET
WRITE1_L:
	CLR   A
;    MOV   DPL,A
;    MOV   DPH,A                          ; clear DPTR
;    MOV   DPP,A
;    MOV   DPTR, #0
    POP   ACC
    MOV   R5, A
    PUSH  ACC
    CJNE  R5, #0, WRITE2_L
    MOV   EDATA3, #0
    RET
WRITE2_L:
    INC   EDATA3
    DEC   R5
    RET
INC_L:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    CLR   A
    POP   ACC
    CJNE  A, #0, INC1                   ; if A != 0 goto INC1
                                        ; else
    PUSH  ACC
    MOV   LCD_DATA, #0c0h               ; kursor na 2 linii
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM0_T                 ; 0
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC1:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #1, INC2                   ; if A != 1 goto INC2
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM1_T                 ; 1
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC2:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #2, INC3                   ; if A != 2 goto INC3
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM2_T                 ; 2
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC3:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #3, INC4                   ; if A != 3 goto INC4
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM3_T                 ; 3
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC4:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #4, INC5                   ; if A != 4 goto INC5
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM4_T                 ; 4
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC5:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #5, INC6                   ; if A != 5 goto INC6
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM5_T                 ; 5
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC6:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #6, INC7                   ; if A != 6 goto INC7
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM6_T                 ; 6
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC7:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #7, INC8                   ; if A != 7 goto INC8
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM7_T                 ; 7
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC8:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #8, INC9                   ; if A != 8 goto INC9
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM8_T                 ; 8
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   INC_L
INC9:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #9, ERR_I                 ; if A != 9 goto ERR
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    MOV   DPTR, #NUM9_T                 ; 9
    CALL  CIAG_ZN
    CLR   A
    CALL  WAIT_D                        ; ===== TUTAJ DO WAIT FOR INT0 =====
    JMP   DEC_L
ERR_I:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #ERR_T
    CALL  CIAG_ZN
    JMP   PTL
DEC_L:
;    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #9, DEC8                   ; if A != 9 goto DEC8
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC8:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #8, DEC7                   ; if A != 8 goto DEC7
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC7:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #7, DEC6                   ; if A != 7 goto DEC6
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC6:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #6, DEC5                   ; if A != 6 goto DEC5
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC5:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #5, DEC4                   ; if A != 5 goto DEC4
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC4:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #4, DEC3                   ; if A != 4 goto DEC3
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC3:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #3, DEC2                   ; if A != 3 goto DEC2
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC2:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #2, DEC1                   ; if A != 2 goto DEC1
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC1:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #1, DEC0                   ; if A != 1 goto DEC0
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC0:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
    CJNE  A, #0, ERR_D                  ; if A != 0 goto ERR
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  WRITEFLASH
    CLR   A
    CALL   WAIT_I                           ; ===== TUTAJ DO WAIT FOR INT0 =====
    JMP INC_L
ERR_D:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #ERR_T
    CALL  CIAG_ZN
    JMP   PTL
; 1 sekundowa przerwa                  -
DLY3:
    MOV R4, #0Ah                         ; definicja ilości powtórzeń pętli 3 (10)
PETLA3:
    MOV R3, #0C8h                        ; definicja ilości powtórzeń pętli 2 (200)
PETLA2:
    MOV R2, #0F8h                        ; definicja ilości powtórzeń pętli 1 (248)
PETLA1:
    DJNZ R2, PETLA1                      ; wykonanie pętli 1
    DJNZ R3, PETLA2                      ; wykonanie pętli 2
    DJNZ R4, PETLA3                      ; wykonanie pętli 3
    RET
RESET_L:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #PROG_T1
    CALL  CIAG_ZN
    ACALL LCD_ROZKAZ
    MOV   DPTR, #PROG_T2
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  DLY3
    CALL  DLY3
    CALL  WAIT_I
    JMP   INC_L
WAIT_I:
    CALL WAIT_C
    ACALL LCD_ROZKAZ
    MOV   DPTR, #CLOSED_T
    CALL  CIAG_ZN
    JB   BUTTON, $                     ; Oczekiwanie na wcisniecie INT0
    RET
WAIT_D:
    CALL WAIT_C
    ACALL LCD_ROZKAZ
    MOV   DPTR, #OPEN_T
    CALL  CIAG_ZN
    RET
WAIT_C:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #WAIT_T
    CALL  CIAG_ZN
    RET
PTL:
    JMP PTL
; Initializacja LCD                    -
LCD_INIT:
    MOV   LCD_PORT, #00h
    MOV   LCD_DATA, #33h                ; Pierwsze slowo dodatkowe progr. LCD
    ACALL LCD_ROZKAZ
    MOV   LCD_DATA, #32h                ; Drugie slowo dodatkowe progr. LCD
    ACALL LCD_ROZKAZ
    MOV   LCD_DATA, #28h                ; Czterobitowy interfejs (F)
                                        ; Dwa wiersze, znak 5x7 punktow
;    MOV   LCD_DATA, #2Ch                ; Czterobitowy interfejs (F)
;                                        ; Dwa wiersze, znak 5x10 punktow
    ACALL LCD_ROZKAZ
    MOV   LCD_DATA, #01h                ; Czyszcz. ekranu, kursor na 0
    ACALL LCD_ROZKAZ                    ; (A)
    MOV   LCD_DATA, #0Fh                ; Wlaczenie ekranu i kursora
    ACALL LCD_ROZKAZ                    ; mrugajacego  (D)
    RET
; Wyslanie pojedynczego rozkazu z      -
; LCD_DATA do wyswietlacza             -
LCD_ROZKAZ:
    MOV   LCD_PORT, #00h
    ACALL LCD_WRITE4
    ACALL LCD_WRITE4
    ACALL DELAY
    RET
; Wyswietlenie pojedynczego znaku z    -
; LCD_DATA na wyswietlacz              -
LCD_DISPLAY_CHAR:
    SETB  LCD_RS
    ACALL LCD_WRITE4
    ACALL LCD_WRITE4
    ACALL DELAY
    RET
DELAY:
    PUSH LCD_PORT                       ; Odczyt BF
    CLR  LCD_RS
    setb LCD_D7
    setb LCD_RW
    setb LCD_E
    jb   LCD_D7,$                       ;Oczekiwanie na zgloszenie gotowosci
    setb LCD_KEY
    POP  LCD_PORT
    ret
LCD_WRITE4:
    PUSH ACC
    CLR  LCD_E
    MOV  A, LCD_DATA
    RLC  A
    MOV  LCD_D7, C                      ; D7
    RLC  A
    MOV  LCD_D6, C                      ; D6
    RLC  A
    MOV  LCD_D5, C                      ; D5
    RLC  A
    MOV  LCD_D4, C                      ; D4
    SETB LCD_E                          ; STROB
    CLR  LCD_E
    MOV  LCD_DATA, A
    POP  ACC
    RET
; Wylanie ciagu znakow rozpoczynajacych-
; sie od adresu podanego w DPTR i      -
; zakonczonego 80h (jest to znak nie   -
; definiujacy znak wyswietlany na      -
; wyswietlaczu oraz znak do CG RAM )   -
CIAG_ZN:
    NOP
K_ZNAK:
    MOV  A, #0
    MOVC A, @A+DPTR
    ADD  A, #80H
    JZ   K_STR
    ADD  A, #80H
    INC  DPTR
    MOV  LCD_DATA, A
    CALL LCD_DISPLAY_CHAR
    JMP  K_ZNAK
K_STR:
    RET
INC_TXT:
    DB 'Otwieranie: '
    DB 80h
DEC_TXT:
    DB 'Zamykanie: '
    DB 80h
NUM0_T:
    DB '0'
    DB 80h
NUM1_T:
    DB '1'
    DB 80h
NUM2_T:
    DB '2'
    DB 80h
NUM3_T:
    DB '3'
    DB 80h
NUM4_T:
    DB '4'
    DB 80h
NUM5_T:
    DB '5'
    DB 80h
NUM6_T:
    DB '6'
    DB 80h
NUM7_T:
    DB '7'
    DB 80h
NUM8_T:
    DB '8'
    DB 80h
NUM9_T:
    DB '9'
    DB 80h
ERR_T:
    DB 'Blad licznika!'
    DB 80H
DLY_T:
    DB 'Op',4,6,'nienie'
    DB 80h
WAIT_T:
    DB 'Wci',5,'nij INT0'
    DB 80h
PROG_T1:
    DB 'Witam w program'
    DB 80H
PROG_T2:
    DB 'ie bramy gara',7,'.'
    DB 80H
CLOSED_T:
    DB 'Brama zamkni',2,'ta'
    DB 80H
OPEN_T:
    DB 'Brama otwarta'
    DB 80H
EDATA1_0:
    DB 'EDATA1_0'
    DB 80H
EDATA1_N0:
    DB 'EDATA1_N0'
    DB 80H
WAIT_TXT:
    DB 'Oczekiwanie'
    DB 80H
; zdefiniowane polskie znaki gdyby     -
; jakis tkst je zawieral to nalezy     -
; napisac (Grzegrzolka):               -
; DB 'Grzegrz', 4, 3, 'ka'             -
TAB_3:
    DB  0,  0, 14,  1, 15, 17, 15,  2    ;znak ą o kodzie 0
    DB  4,  0, 15, 16, 16, 17, 15,  0    ;znak ć o kodzie 1
    DB  0,  0, 14, 17, 31, 16, 14,  2    ;znak ę o kodzie 2
    DB 12,  4,  6,  4, 12,  4, 14,  0    ;znak ł o kodzie 3
    DB  2,  4, 14, 17, 17, 17, 14,  0    ;znak ó o kodzie 4
    DB  2,  4, 14, 16, 14,  1, 30,  0    ;znak ś o kodzie 5
;    DB  2,  4, 22, 25, 17, 17, 17,  0    ;znak ń o kodzie 5
    DB  2,  4, 14, 16, 14,  1, 30,  0    ;znak ź o kodzie 6
    DB  4,  0, 31,  2,  4,  8, 31,  0    ;znak ż o kodzie 7
    DB 80h
END
And example code from CD-ROM:
; Author        : ADI - Apps            www.analog.com/MicroConverter
; Date          : October 2003
; File          : dataflsh.asm
; Hardware      : ADuC842/ADuC843
; Description   : Demonstrates use of the on-chip read/write 4096 byte
;                 FlashEE data memory space.  Stores a sequence of
;                 button presses (INT0 button on eval board) in data
;                 FlashEE space.  Replays sequence on LED when board
;                 is reset or power cycled.
;                 The ADuC842 stores the play sequece in data flash
;                 until another is recorded with a new set of button
;                 presses.  To record a new sequence, just wait until
;                 the current one finishes playing (LED is off) and
;                 enter new sequence via button (INT0).
$MOD842                         ; Use 8052&ADuC842 predefined symbols
LED      EQU    P3.4            ; P3.4 drives red LED on eval board
BUTTON   EQU    P3.2            ; button on eval board drives P3.2
PREVIOUS EQU    F0              ; flag to hold previous button value
;____________________________________________________________________
                                                  ; BEGINNING OF CODE
CSEG
ORG 0000h
MAIN:
    CLR     LED             ; turn LED off
	MOV     EADRH,#0        ; set data FlashEE address to page 0
    MOV     EADRL,#0
; READ FLASH/EE DATA and indicate values via LED on and off times...
READFLASH:
        MOV     ECON,#READ      ; read current 4byte page of FlashEE
                                ; into EDATA1,2,3,4
        MOV     A,EDATA4
        CJNE    A,#1,RECORD     ; if EDATA4 is 1, then page contains
                                ; a valid play sequence
                                ;        => Play this sequence
                                ; otherwise jump to record mode
PLAYBACK:
        CALL    BLINK           ; flash LED for period determined
                                ; by FlashEE data just read
        MOV     A,EADRL
        CJNE    A,#0FFh,INCPAGE1 ; if low address is FFh then increment high address
	INC     EADRH
INCPAGE1:
        INC     EADRL           ; increment to next FlashEE page addr
        MOV     A,EADRH
        CJNE    A,#04h,READFLASH
                                ; if address is less than 160 then jump
                                ; to read the next page
       ; when PLAYBACK is finished jump to RECORD mode
RECORD:
        CLR     LED
        JB      BUTTON,$        ; wait for first button press
        ; once button is pressed, erase dataflash
        MOV     ECON,#ERASEALL  ; clear all data FlashEE memory
        MOV     EADRH,#0
        MOV     EADRL,#0
        ; record time of button press
RECORD_NEXT_TIME:
        CALL    RECORDTIME
        MOV     EDATA1,DPL      ; place DPTR in EDATA1,2,3
        MOV     EDATA2,DPH
        MOV     EDATA3,DPP
        MOV     EDATA4,#1       ; put 1 in EDATA4 as identifier
        MOV     ECON,#WRITE     ; write EDATA1-4 into pre-erased
        MOV     ECON,#VERIFY    ; verify current page is same as
        MOV     A,ECON          ; EDATA1-4.  If same, ECON=0.
        JNZ     RECORD          ; if verify fails, jump to RECORD
        MOV     A,EADRL
        CJNE    A,#0FFh,INCPAGE2 ; if low address is FFh then increment high address
	INC     EADRH
INCPAGE2:
        MOV     A,EADRH
        CJNE    A,#04h,RECORD_NEXT_TIME
                                ; record first 160 button presses only
        ; when flash/EE data space is full turn off LED and wait
        ; for a power cycle
        CLR     LED
        JMP     $
;                             FUNCTIONS
                                                        ; SUBROUTINES
BLINK:
        ; Turn LED ON/OFF based on the time in EDATA3/2/1
        CPL     LED
	CLR     A
        MOV     DPL,A
        MOV     DPP,A
        INC     EDATA1          ; EDATA1 -> EDATA3 should be
        INC     EDATA2          ; incremented for the below to work
        INC     EDATA3
BLINKLOOP:
        ; the record loop takes 11 instruction cycles hence 7 NOPs are
        ; required to make the Playback loop 11 instruction cycles also.
        ; NOTE: the main Playback loop will jump to BLINKLOOP after
        ; decrementing EDATA1 and hence the time required to decrement
        ; EDATA2 (approx 1/256 time of main loop) and EDATA3 are ignored.
        NOP                                                       ; 1
        NOP                                                       ; 1
        NOP                                                       ; 1
	NOP                                                       ; 1
        NOP                                                       ; 1
        NOP                                                       ; 1
        NOP                                                       ; 1
        DJNZ    EDATA1, BLINKLOOP                                 ; 4
	DJNZ	EDATA2, BLINKLOOP ; EDATA1 overflows back to FFh
        DJNZ    EDATA3, BLINKLOOP ; EDATA2 overflows back to FFh
        RET
RECORDTIME:
        ; Record how long button is pressed for and store in EDATA3/2/1
	CLR     A
        MOV     DPL,A
        MOV     DPP,A
        CPL     LED
        ; measure how long the button is either pressed or released
        ; for. If the button is pressed then the LED is on. If the
        ; button is released then the LED is off.
RECORDLOOP:
        INC     DPTR            ; incrementing DPTR..           ;  3
        JNB     LED, CHKB                                       ;  4
        JNB     BUTTON,RECORDLOOP                               ;  4
                                ; keep recording while button is pressed
        RET
CHKB:   JB      BUTTON,RECORDLOOP                               ;  4
                                ; keep recording while button is released
        RET
; DPP,DPH,DPL now holds a number that represents the length of
; time between button edges.  this data will be stored in FlashEE
; space for use in controlling LED on and off times in "play" mode.
END
Datasheet of ADuC842: https://www.analog.com/en/processors-dsp/analog-microcontrollers/aduc842/products/product.html
Comments are in polish so if you want to know what they mean please use google translate ;) My lecturer is old school so he does not know English well.
If someone finds solution I will be gratefull, at this time i will struggle with this problem.
I made it!
In INC_L, INC#, DEC_L and DEC# I must call erase EEPROM, get back, set EDATA1 value manually like MOV EDATA1, #2, call write to EEPROM, get back and continue the open/close loop.
In the beginning i need to put ACC on the stack, because open/close loops get ACC off the stack.
My code:
LCD_D4      EQU P2.1
LCD_D5      EQU P2.0
LCD_D6      EQU P2.3
LCD_D7      EQU P2.2
LCD_E       EQU P2.5
LCD_RW      EQU P2.4
LCD_RS      EQU P2.7
LCD_KEY     EQU P2.6
LCD_PORT    EQU P2
                                        ; DO WYSWIETLACZA
ORG  0000h
MOV   DPTR, #TAB_3
CALL  RESET_L
MAIN:
    MOV   EADRL, #0
READFLASH:
                                        ; into EDATA1,2,3,4
    CLR   A
    MOV   A, EDATA4
                                        ; a valid ACC
                                        ;        => read EEPROM
READ_EE:
    CALL  READ1_L
    JMP   WAIT_I
READ1_L:
    CLR   A
    MOV   A, EDATA1
    CJNE  A, #0, READ2_L
    RET
READ2_L:
    PUSH  ACC
    JMP   WAIT_D
START:
    CLR   A
    MOV   A, #0
    CALL  WAIT_I
WRITEFLASH:
    MOV   EADRH, #0
    MOV   EADRL, #0
    RET
WRITE_EE:
    RET
WRITE1_L:
    CLR   A
    MOV   EDATA1, A
    MOV   EDATA2, A
    MOV   EDATA3, A
    POP   ACC
    MOV   EDATA2, A
    PUSH  ACC
    RET
INC_L:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    CLR   A
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #0
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC1:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #1
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC2:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #2
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC3:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #3
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC4:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #4
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC5:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #5
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC6:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #6
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC7:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #7
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC8:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #8
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    INC   ACC
    PUSH  ACC
    JMP   INC_L
INC9:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #INC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  WRITEFLASH
    MOV   EDATA1, #9
    CALL  WRITE_EE
    CLR   A
    JMP   WAIT_D                        ; ===== TUTAJ DO WAIT FOR INT0 =====
ERR_I:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #ERR_T
    CALL  CIAG_ZN
    JMP   PTL
DEC_L:
;    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #9
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC8:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #8
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC7:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #7
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC6:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #6
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC5:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #5
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC4:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #4
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC3:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #3
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC2:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #2
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC1:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  WRITEFLASH
    MOV   EDATA1, #1
    CALL  WRITE_EE
    CLR   A
    POP   ACC
    DEC   ACC
    PUSH  ACC
    CALL  WRITEFLASH
    JMP   DEC_L
DEC0:
    PUSH  ACC
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #DEC_TXT
    CALL  CIAG_ZN
    POP   ACC
                                        ; else
    PUSH  ACC
    ACALL LCD_ROZKAZ
    CALL  CIAG_ZN
    CALL  WRITEFLASH
    MOV   EDATA1, #1
    CALL  WRITE_EE
    CLR   A
    JMP   WAIT_I                           ; ===== TUTAJ DO WAIT FOR INT0 =====
ERR_D:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #ERR_T
    CALL  CIAG_ZN
    JMP   PTL
DLY3:
PETLA3:
PETLA2:
PETLA1:
    RET
RESET_L:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #PROG_T1
    CALL  CIAG_ZN
    ACALL LCD_ROZKAZ
    MOV   DPTR, #PROG_T2
    CALL  CIAG_ZN
    CALL  DLY3
    CALL  DLY3
    RET
WAIT_I:
    CALL  WAIT_C
    ACALL LCD_ROZKAZ
    MOV   DPTR, #CLOSED_T
    CALL  CIAG_ZN
    JMP   INC_L
WAIT_D:
    CALL  WAIT_C
    ACALL LCD_ROZKAZ
    MOV   DPTR, #OPEN_T
    CALL  CIAG_ZN
    JMP   DEC_L
WAIT_C:
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    MOV   DPTR, #WAIT_T
    CALL  CIAG_ZN
    RET
PTL:
    JMP PTL
LCD_INIT:
    MOV   LCD_PORT, #00h
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    ACALL LCD_ROZKAZ
    RET
LCD_ROZKAZ:
    MOV   LCD_PORT, #00h
    ACALL LCD_WRITE4
    ACALL LCD_WRITE4
    ACALL DELAY
    RET
LCD_DISPLAY_CHAR:
    SETB  LCD_RS
    ACALL LCD_WRITE4
    ACALL LCD_WRITE4
    ACALL DELAY
    RET
DELAY:
    CLR  LCD_RS
    setb LCD_D7
    setb LCD_RW
    setb LCD_E
    setb LCD_KEY
    POP  LCD_PORT
    ret
LCD_WRITE4:
    PUSH ACC
    CLR  LCD_E
    MOV  A, LCD_DATA
    RLC  A
    MOV  LCD_D7, C                      ; D7
    RLC  A
    MOV  LCD_D6, C                      ; D6
    RLC  A
    MOV  LCD_D5, C                      ; D5
    RLC  A
    MOV  LCD_D4, C                      ; D4
    SETB LCD_E                          ; STROB
    CLR  LCD_E
    MOV  LCD_DATA, A
    POP  ACC
    RET
CIAG_ZN:
    NOP
K_ZNAK:
    MOV  A, #0
    MOVC A, @A+DPTR
    ADD  A, #80H
    JZ   K_STR
    ADD  A, #80H
    INC  DPTR
    MOV  LCD_DATA, A
    JMP  K_ZNAK
K_STR:
    RET
INC_TXT:
    DB 'Otwieranie: '
    DB 80h
DEC_TXT:
    DB 'Zamykanie: '
    DB 80h
NUM0_T:
    DB '0'
    DB 80h
NUM1_T:
    DB '1'
    DB 80h
NUM2_T:
    DB '2'
    DB 80h
NUM3_T:
    DB '3'
    DB 80h
NUM4_T:
    DB '4'
    DB 80h
NUM5_T:
    DB '5'
    DB 80h
NUM6_T:
    DB '6'
    DB 80h
NUM7_T:
    DB '7'
    DB 80h
NUM8_T:
    DB '8'
    DB 80h
NUM9_T:
    DB '9'
    DB 80h
ERR_T:
    DB 'Blad licznika!'
    DB 80H
DLY_T:
    DB 80h
WAIT_T:
    DB 80h
PROG_T1:
    DB 80H
PROG_T2:
    DB 80H
CLOSED_T:
    DB 80H
OPEN_T:
    DB 'Brama otwarta'
    DB 80H
EDATA1_0:
    DB 'EDATA1_0'
    DB 80H
EDATA1_N0:
    DB 'EDATA1_N0'
    DB 80H
EDATA1_A:
    DB 'EDATA1=A'
    DB 80H
EDATA1_NA:
    DB 'EDATA1!=A'
    DB 80H
WAIT_TXT:
    DB 'Oczekiwanie'
    DB 80H
TAB_3:
    DB 80h
END
