The_Dutchman
Member level 1
ADS Sparam mini-circuits balun 4-port but s3p?
Hello all,
I'm used to working with ADS a little bit, but I can't seem to understand to simulate the TCM4-452X+ wideband balun from mini-circuits.
I downloaded the s3p-file from over here:
Datasheet is here:
First I don't really get why I got a S3P-file while the component has 4 ports? Primary dot, primary, secondary dot and secondary.
Second I don't understand how I should interprete this file? What is corresponding to port 1, 2 and 3? It is not documented as far as I know.
When I try to simulate to find out which port is what I never even get the graphs for return loss (S11) close to the datasheet even switching the excitation port around.
What am I missing here?
Thanks alot!
Apparently I was dumb enough to wrongly interpret the Ohm's ratio of the 1:4 transformer. Instead of having 12.5 Ohms at the secondary it should have been 200 Ohms, hence the mismatch in S11. Now I get figures like this (which are close to the datasheet)
However, my question still remains as I want to use this component for a downconversion in impedance (50 to 12.5 Ohms). Thus I have single-ended 50 Ohm in at the secondary and I want 12.5 Ohm at the primary, differential. But that is not the way the s3p is measured. How should I handle this?
Hello all,
Datasheet is here:
Thanks alot!
