Fairy&cutie
Newbie level 5
- Joined
- Feb 25, 2015
- Messages
- 8
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 3
- Activity points
- 45
"S-parameters are small signal quantities and and they are simulated with small signal equivalent circuits so they are not related to applied signal strength"..
hey BigBoss thanks for the reply, i found it useful, but one more question viz, i was finding the input imepedance of the circuit through S- parameters then doing matching with input source, now that u say that S- parameters are not suitable in this circuit, then what should i do to find the impedance of the load i-e diode, capacitor and resistor in parallel? and what is OP and how did you find the voltage at the diode?
will be waiting for your reply. Thanks.
The input impedance of this circuit is totally bias depended so OP of the diodes is changing with signal amplitude and this is a large amplitude therefore while s-parameters are valid for single OP they are not valid anymore for other OPs.That's why I say you " use transient or HB method"."S-parameters are small signal quantities and and they are simulated with small signal equivalent circuits so they are not related to applied signal strength"..
Impedance matching is not necessary in this case because impedance is variable with OP.The most important here is to have a proper driver circuit that is able to drive this level properly to the diodes.
