grit_fire
Member level 5
Hi, all,
I used ADS momentum to draw two simple square-shape antennas with one single metal layer. I planed to use one of them as transmitter and the other as the receiver. There are two ports in each of the antenna and hence four ports in total.
Then I tried to define two different ports, namely port 1&2 in the first antenna as a group of diff pair and port 3&4 in the second antenna as another group of diff pair. When I tried to define the differential ports using port editor, it returned me the following error:
Port P2 cannot be associated with port number 1.
If they are in the same reference plane, and you want to associate them:
Please set both ports to the correct Port Type before
setting ^Associate with port number^
And this happened as well to port 3&4.
Could anyone help resolve this problem? I have been stuck on this for quite a while...
I really appreciate your help!
