Hello,
Im using ADS 2016 for a simulation. I wanted to include this transistor Design kit (Transistot: SKY65050-372LF, SKY65050 ADS Design Kit).
When I want to install it, I always get this message:
“Could not install design kit, The design kit does not contain a lib.defs file. The most likely cause is that kit is not compatible with ADS2011 and later”
Did any of you ever had this problem, or better found/ knows a solution?
There are two different types of ADS design kits that are NOT compatible: ADS 2009 and earlier, ADS 2011 and later
Can you show a link to the designkit download?
It looks like you have an old ADS 2009 designkit. This will not work, and there is no workound. Only the designkit programmer can make an old ADS 2009 designkit compatible with new ADS version.
