George Sarris
Newbie level 5
- Joined
- Oct 28, 2013
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Delft, Netherlands
- Activity points
- 75
Hello,
I am trying to design coupled line couplers in ADS at 80 GHz. Initially i use the ideal coupled lines to check the performance and all is ok. Then i use a MSUB and i size the lines using the ADS linecalc. Initially i use a conductor of zero thickness and infinite conductivity and i get similar performance between the ideal coupler and the coupler on the actual substrate. Then i give the metal thickness and i set the conductivity to the actual value. I calculate the new dimensions of the coupler, but then the behavior is not the specified one for frequencies above 10 GHz. I know there are effects that affect the current flow of metals at high frequencies. Is the deviation due to inaccurate modelling of the lines in the linecalc tool or am i doing anything wrong?
Thank you in advance.
