ADS Balun simulation question
cmosbjt
Full Member level 5
USA
ads balun
Hi, when simulating a 50 Ohm impedance balun. Which setup is right?
The next question is, what is the impedance looking into one of the balance ports? I guess it should be 50/2 for differential signal, am I right?
If I am right, then if I design 2 identical circuit blocks connecting to the 2 balance ports of the balun, for matching, should each of the circuit blocks have a 25 Ohm input impedance ?
Thanks
balun simulation
the 1st setup is ok , specially the balun is 50 ohm balanced output
khouly
balun ads
All the three configurations are correct. It defers from the output load impedance only. the important thing is both setup 1 and 3 are identical in all aspects like impedance phase char etc. Setup 3 aloows you to simulate for phase and gain imbalances if any.
If you need further clarification please PM.
    cmosbjt
simulating balun
I guess I can answer my own question now:
Both setup 1 and 3 are correct. Setup 1 test the differential s-param at the balance ports. and setup 3 test the single-ended s-param. Result from setup 3 can be converted to the mixed-mode s-param by some equations.
balun, advanced design system
Yes you are right,
Also setup 2 is one form of transformer which is referenced to GND. It is no more called as Balun.
