Hi to all,
I wanted to look in operation example Antenna_with_radome_wrk . However when I launch EM symulation produces an error: Analysis "Solve" (M111202142331) of design Antenna_with_radome_libanel_with_radome:layout failed.
It is an error in the project or nevertheless it is necessary to install EMPro?
Help me please.
Hi to all,
Help me please.
Thanks for the answer. You only couldn't prompt where it is an example? What I it don't find that? (What examples with fem I do not try to launch - all produce errors).
EMPro is another product from ADS. The two are not the same, though are both produced by Agilent. As such, it is quite possible you have been given an EMPro file which you will never be able to use unless you get an EMPro license.
I would add, I've not used EMPro or ADS except for the briefest of tests, so don't even know the file names they use.
I know that it is two different products.
The given file is given as usage of technology FEM at modeling in ADS. Here at me also it is impossible to launch this example.
