address of lock bit in 8051
The exact location of lock bits in 8051-derivatives which have them is undisclosed ..
They are somewhere in the program memory (Flash, EPROM or OTP) and you can find in data sheet of a particular derivative how to program, read or erase (only together with program memory, if applicable) them .. see example below ..
Regards,
IanP
You can't erase just the lock bits, you have to use CHIP ERASE procedure and only then the lock bits will be erased - including all bytes of the program memory ..
Regards,
IanP
