Adding Y value on different X position (time)
north2012
Member level 3
Member level 3
Hello,
I am working with small WSN with coordinator and 3 nodes. Coordinator ("Hall") collects all data (measured temperature, relative humidity and light intensity) from nodes ("Bedroom", "Lounge", "Bathroom") and through serial interface send it to PC where I have PC application for data acquisition and presentation.
First step:
chart1.Series["Hall"].ChartType = SeriesChartType.FastLine;
chart1.Series["Hall"].Color = Color.Red;
chart1.Series["Bedroom"].ChartType = SeriesChartType.FastLine;
chart1.Series["Bedroom"].Color = Color.Blue;
chart1.Series["Lounge"].ChartType = SeriesChartType.FastLine;
chart1.Series["Lounge"].Color = Color.Brown;
chart1.Series["Bathroom"].ChartType = SeriesChartType.FastLine;
chart1.Series["Bathroom"].Color = Color.Green;
chart1.Legends["Legend1"].Docking = Docking.Top;
After package is received and parsing one of charts is updated
DateTime now = DateTime.Now;
date = now.ToString("dd/MM/yy");
chart1.Series["Hall"].Points.AddXY(time, halltemperature);
chart1.Series["Bedroom"].Points.AddXY(time, bedroomtemperature);
chart1.Series["Lounge"].Points.AddXY(time, loungetemperature);
chart1.Series["Bathroom"].Points.AddXY(time, bathroomtemperature);
The problem is that nodes can join in network in different moments, but new graph is always started from zero position even it is different time.
"Hall" joins first and that graph is started. For example, after 4-5 seconds new node is added but that graph starts from zero and so on... How to add offset to X value to?
I have global time, variable DateTime now = DateTime.Now; is global and it is updated on every new results.
I will try to explain my problem:
1. I have only the coordinator in network. It has own temperature, RH and light sensor so graphs are started.
2. For example, 5 seconds later the second node ("Bedroom") joined the network. It has own temperature, RH and light sensor so graphs are started for this node as well.
3. On the mutual graph, I have 5 samples of "Hall" temperature and 1 sample of "Bedroom" temperature. Graphs are plotted versus time and 19:47:52 is zero x-axis value for "Bedroom" and the fifth x-axis value for "Hall". I would like to make that "Bedroom" graph starts with offset of five, before that it should be clear. So, measured values for both temperatures ("Hall" and "Bedroom") on 19:47:53 will be plotted as the sixth x-axis value. Is this possible?
Thanks.
still not sure what the problem is
the C# program bleow plots a sine wave (one degree/second) on a Chart component and when the Start Cosine button is pressed also plots the cosine - it can be seen cosine starts plotting after about 300degrees (it is clear before that)
could you upload a sample of your chart to show the problem
Hello,
Sorry for late response.
Here are my graphs.
As you can see, even both values have the same time, they are not placed on the same time position on x-axis...
Line for adding new value on graphs is
or
These are called in function update_values
private void update_values(string update)
        time = now.ToString("HH:mm:ss");
//parse of "update" string
//one of upper lines
