adding of ZAP file to ADS 2011.10 schematic
dineshmoorthy
Newbie level 6
Newbie level 6
dear sir
i have ZAP file of ATF 54143 p HEMT which i have use for my design, but i am unable to extract it
in ADS 2011.10.
kindly help me
thank you
A ZAP file is an archive of a project from earlier version of ADS. This file can be used in ADS 2011.10 if it is opened using the command File > Unarchive... from the ADS main window. This will unarchive this project and automatically convert it to and ADS 2011.10 workspace. This workspace will contain the cell views (schematic & symbol) for the transistor model.
dear sir
thank for you reply
i donot find command line option in the ADS main window in order to unarchive the ZAP file. kindly clarify please
thank you
In ADS 2011.10 main window to be exact it is labelled File > Unarchive Workspace or Project... This command handles all kind of ADS archive file types (*.*zap).
sir
thank you , i able to extract the schematic and symbol. i have a query that is it possible to push the schematic of the transistor into palatte of the ADS . if possible kindly tell the steps
thank you
There is no simple/easy way to add a design that exists in a workspace/project on to the palette groups. It would need to be configured, along with the necessary palette bitmap files and configuration files, into a Design Kit/PDK to get that to work.
