Adding an offset voltage to a signal
T
treez
Hi
As in the attached schematic, we wish to add a 1.2V offset to the signal “HSIN”.
The circuit does it but needs two opamps and a negative supply. Is their not a lower component count way of doing this?
  • Adding an offset voltage.pdf
What precision do you need?
What is the load impedance?
And how is "vbus/300" made?
Klaus
Thanks, Precision around +/-0.05v
vbus/300 is made from a potential divider fed to a opamp buffer.
Load impednace >10Meg
Still unclear how the Vbus/300 is generated.
Thus the simplest circuit I can think of:
V_bus/300 - 1.2V shunt reference - (output) - pullup.
Klaus
Reactions: treez
    T
Here's a single supply, single op amp circuit that adds the offset.
How do you plan on generating the 1.2V?
Reactions: treez
    T
