I work on a ship which has Public Announcement (PA) system. PA system consists of a couple of zones. Each zone has an a controller, amplifier and a loudspeakers circuit.
In our case, PA system is only used to make announcements and play alarm, not music.
What I need to do is to add a light indication which will be activated when, for example, zone A is activated (meaning that loudspeakers in zone A are producing sound).
I can definitely do it by using one of the control outputs from the controller, but it would take a lot of cable pulling. It would be much more simple if I could just
connect a light parallel to one of the loudspeakers.
Now... my concerns are:
1) When I look at the drawing of one zone, the output from the amplifier to the loudspeakers is 100V. Am I right to suppose this is 100VAC "high" frequency (by "high" I mean higher than 50/60Hz), depending on the input signal?
2) There is around 50 loudspeakers in a zone where I would like to add the light. Each loudspeaker has a marking 100V, 25W, 101dB. If I add a 220V 20W halogen light (which is purely resistive load) in parallel to the loudspeakers, am I going to disturb i any way the loudspeakers circuit or the amplifier (assuming the amplifier will not get overloaded)?
3) Is it correct to calculate the approximate current through the individual loudspeaker I = P/U = 25W/100VAC = 0.25A?
