vir_paksh@yahoo.co.in
Newbie level 6
adc_lcd programing in c for pic16f877A:In proteus woks fine but in circuit it is not
Please help me where is the problem in the below program, In proteaus simulation it works very fine and reads as I required, but when working with circuit it is not reading the adc but displaying some other junk values from where I don't know & being on change in values, totally it is not reading while working in circuit, anybody please correct the program to read adc in working circuit
Thanks & Regards
View attachment ADC sens2.pdf
Thanks & Regards
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 #include<htc.h> #include<string.h> #include<stdio.h> #include<math.h> // __CONFIG(FOSC_EXTRC & WDTE_OFF & PWRTE_OFF & CP_OFF & BOREN_OFF & LVP_ON & CPD_OFF & WRT_ON); //__CONFIG(FOSC0_RC & WDTE_OFF & PWRT_ON & CP0_OFF & BOREN_ON & LVP_OFF & CPD_OFF & WRT_ON & DEBUG_ON); __CONFIG(0X3F72); //__CONFIG( FOSC_HS & WDTE_OFF & PWRTE_ON & CP_OFF & BOREN_ON // & LVP_OFF & CPD_OFF & WRT_ON & DEBUG_OFF); volatile bit Data @ (unsigned)&PORTD*8+7; volatile bit RS @ (unsigned)&PORTD*8+6; volatile bit EN @ (unsigned)&PORTD*8+5; volatile bit Clk @ (unsigned)&PORTD*8+4; volatile bit GODONE @ (unsigned)&ADCON0*8+2; #define FCY 4000000 #define MILLISEC (FCY/10000) #define AN0 ((Ch0/1024.0)) //for i/p value = 4V #define AN1 ((Ch1/1024.0)) //for value = 2 #define AN2 ((Ch2/1024.0)) // for o/p value = 1.2V #define AN3 ((Ch3/1024.0)) //for value = 1.8 #define AN4 ((Ch4/1024.0)) //for i/p value = 4V #define AN5 ((Ch5/1024.0)) //for value = 2 #define AN6 ((Ch6/1024.0)) // for o/p value = 1.2V #define AN7 ((Ch7/1024.0)) //for value = 1.8 #define ANSEL 0 #define OFFSET 10 #define SIGNAL1 PORTBbits.RB0 int; void DelayN1mSec(unsigned int S1); void Write_LCD_Nibble(unsigned int); void Write_LCD_Data(unsigned int); void Write_LCD_Cmd(unsigned int); void Initialize_LCD(void); void Position_LCD(unsigned int, unsigned int); void Write_LCD_Text(char*); //void Write_LCD_String(s*); void Load_Msg(float v,unsigned char OutD[]); unsigned int ADCRead(unsigned char channel); void SetPWMDutyCycle1(void); void DelayN2mSec(unsigned int S2); void DelayNmSec(unsigned int S3); unsigned int Nibble, p, q, Mask, t; unsigned int Ch0, Ch1, Ch2, Ch3,Ch4,Ch5,Ch6,Ch7; long int Outvalue,Outvalue1,Outvalue2,Outvalue3,Outvalue4,Outvalue5,Outvalue6,Outvalue7; unsigned int temp1,temp2,DataX1,DataX2,temp3,temp4,DataX3,DataX4,temp5,temp6,DataX5,DataX6,temp7,temp8,DataX7,DataX8,Name,UPS,Freq; char Message1[] = {"Input_PP: 000.0V "}; //ADCRead(2); char Message2[] = {"Output_PP:000.0V "}; char Message3[] = {"R_ph_out: 000.0A "}; char Message4[] = {"Y_ph_out: 000.0A "}; char Message5[] = {" B_ph_out:000.0A "}; char Message6[] = {" Bat_Volt:000.0V "}; char Message7[] = {" Ba_ch_cnt:00.0A "}; char Message8[] = {" Tempr: 0.0C "}; char Message9[] = {"VIRUPAKSH9 7 "}; //ADCRead(2); char Message10[]= {"OnLineUPS: "}; char Message11[]= {" 50Hz,Sine "}; char Message12[]= {"SineWave: "}; void main() { TRISD = 0b00000000; // All Outputs except GP3 // TRISA = 0b00000000; PORTD = 0b00000000; // PORTA = 0b00000000; PORTB = 0b00000000; TRISB = 0b00000000; PORTC = 0b00000000; TRISC = 0b00000000; // ANSEL = 0x00; // No analog i/p //GPIO = 0b00000000; //CMCON = 7; //Disable ADC do { Initialize_LCD(); TRISA = 0b10111111; PORTA = 0b10111111; TRISE = 0b00000111; PORTE = 0b00000111; PORTD = 0; TRISD = 0; PORTB = 0; TRISB = 0; TRISC = 0; PORTC = 0; ADCON0 = 0xC7; ADCON1 = 0x80; //check this value Outvalue1 =AN0; DataX1 = Ch0*5; Outvalue2 =AN1; DataX2 = Ch1*1; Outvalue3 =AN2; DataX3 = Ch2*1; Outvalue4 =AN3; DataX4 = Ch3*1; Outvalue5 =AN4; DataX5 = Ch4*1; Outvalue6 =AN5; DataX6 = Ch5*1; Outvalue7 =AN6; DataX7 = Ch6*1; Outvalue =AN7; DataX8 = Ch7*1; temp1 = (unsigned int)DataX1; // temp2 = (unsigned int)DataX2; temp3 = (unsigned int)DataX3; // temp4 = (unsigned int)DataX4; temp5 = (unsigned int)DataX5; // temp6 = (unsigned int)DataX6; temp7 = (unsigned int)DataX7; // temp8 = (unsigned int)DataX8; Ch0 =ADCRead(0x81); //ok Ch1 =ADCRead(0x89); //ok Ch2 =ADCRead(0x91); //ok Ch3 =ADCRead(0x99); //ok Ch4 =ADCRead(0xA1); //ok Ch5 =ADCRead(0xA9); //ok Ch6 =ADCRead(0xB1); //ok Ch7 =ADCRead(0xB9); //ok Write_LCD_Cmd(0x01); // Clear LCD DelayNmSec(3); Load_Msg(DataX1,Message1); DelayNmSec(3); Write_LCD_Cmd(0xC0); // Clear LCD DelayNmSec(3); Load_Msg(DataX2,Message2); DelayNmSec(3); Write_LCD_Cmd(0x93); // Clear LCD DelayNmSec(3); Load_Msg(DataX6,Message6); DelayNmSec(3); Write_LCD_Cmd(0xD3); // Clear LCD DelayNmSec(3); Load_Msg(DataX7,Message7); DelayNmSec(300); Write_LCD_Cmd(0x01); // Clear LCD DelayNmSec(3); Load_Msg(DataX3,Message3); DelayNmSec(3); Write_LCD_Cmd(0xC0); // Clear LCD DelayNmSec(3); Load_Msg(DataX4,Message4); DelayNmSec(3); Write_LCD_Cmd(0x93); // Clear LCD DelayNmSec(3); Load_Msg(DataX5,Message5); DelayNmSec(3); Write_LCD_Cmd(0xD3); // Clear LCD DelayNmSec(3); Load_Msg(DataX8,Message8); DelayNmSec(300); Write_LCD_Cmd(0x01); // Clear LCD DelayNmSec(3); Load_Msg(Name,Message9); DelayNmSec(3); Write_LCD_Cmd(0xC0); // Clear LCD DelayNmSec(3); Load_Msg(UPS,Message10); DelayNmSec(3); Write_LCD_Cmd(0x93); // Clear LCD DelayNmSec(3); Load_Msg(Freq,Message11); DelayNmSec(300); } while(1); } unsigned int ADCRead(unsigned char channel) { unsigned char l_byte, h_byte; unsigned int ADR; ADCON0 = channel; //Change channel //delay_us(50); DelayNmSec(25); //Acquisition Delay GODONE = 1; //Set GO_DONE bit to start conversion while(GODONE == 1); //Wait for bit to be cleared //If bit is cleared, this means conversion is over l_byte = ADRESL; h_byte = ADRESH; ADR = (h_byte<<8)|l_byte; return ADR; } void DelayN1mSec(unsigned int S1) { unsigned long int j1; while(S1--) for(j1=0;j1<MILLISEC;j1++); } void DelayN2mSec(unsigned int S2) { unsigned long int j2; while(S2--) for(j2=0;j2<MILLISEC;j2++); } void DelayNmSec(unsigned int S3) { unsigned long int j3; while(S3--) for(j3=0;j3<MILLISEC;j3++); } void Write_LCD_Nibble(unsigned int N) { unsigned int Flag; // ****** Write RS ********* EN = 0; Clk = 0; Clk = 1; Clk = 0; // ****** End RS Write // Shift in 8 bits for (t=0; t<8; t++) { switch(t) { case 0 : Mask=8;break; case 1 : Mask=128;break; case 2 : Mask=64;break; case 3 : Mask=32;break; case 4 : Mask=16;break; case 5 : Mask=4;break; case 6 : Mask=2;break; case 7 : Mask=1;break; } Flag = N & Mask; if(Flag==0) { Data = 0; } else { Data = 1; } Clk = 1; Clk = 0; } //Data = 0; EN = 1; EN = 0; } // ******* Write Nibble Ends void Write_LCD_Data(unsigned int D) { RS = 1; // It is Data, not command Nibble = D; Write_LCD_Nibble(Nibble); } void Write_LCD_Cmd(unsigned int C) { RS = 0; // It is command, not data Nibble = C; Write_LCD_Nibble(Nibble); } void Initialize_LCD() { Write_LCD_Cmd(0x30); // Wake-Up Sequence DelayNmSec(2); Write_LCD_Cmd(0x30); DelayNmSec(2); Write_LCD_Cmd(0x30); DelayNmSec(2); Write_LCD_Cmd(0x0F); DelayNmSec(2); Write_LCD_Cmd(0x38); // 8-bits, 2 lines, 5x7 font DelayNmSec(2); Write_LCD_Cmd(0x0C); // Display ON, No cursors DelayNmSec(2); Write_LCD_Cmd(0x06); // Entry mode- Auto-increment, No Display shifting DelayNmSec(2); Write_LCD_Cmd(0x01); DelayNmSec(2); } void Position_LCD(unsigned int x, unsigned int y) { unsigned int temp; temp = 127 + y; if (x == 2) { temp = temp + 64; } Write_LCD_Cmd(temp); } void Write_LCD_Text( char *StrData) { unsigned int temp; q = strlen(StrData); for (p = 0; p<q; p++) { temp = StrData[p]; Write_LCD_Data(temp); } } void Load_Msg(float v,unsigned char OutD[]) { v *= 10.0; unsigned int k1 = (int)v; unsigned char c; c = k1/1000; if(c > 0) k1 = k1 - c*1000; OutD[OFFSET] = (c + 0x30); c = k1/100; if(c > 0) k1 = k1 - c*100; OutD[OFFSET+1] = (c + 0x30); c = k1/10; if(c > 0) k1 = k1 - c*10; OutD[OFFSET+2] = (c + 0x30); OutD[OFFSET+4] = (char)(k1 + 0x30); Write_LCD_Text(OutD); }
