kaka919
Newbie level 5
Adc0808 is giving output 00 for 0v and 255 for 5v which is correct, however for analog input between 0 and 5v, it's giving random values.
Clock to adc is given via timer of 8051. Using timer 0 interrupt, I;m generating a 100 Khz frequency which is given to clock pin of ADC 0808.
Can anyone please help me with this? Thank You
#define start_conv P3_0
#define end_conv P3_1
#define output_enable P3_2
#define clock_output P3_3
#define address_latch P3_4
#define ADDA P3_5
#define ADDB P3_6
#define ADDC P3_7
#define buzzer P0_3
#define data_bus P1
unsigned char val=0;
char buffer[33];
void mydelay(unsigned int temp)
while(temp--);
//ISR sequence for the timer 0
void timer0() interrupt 1
if(clock_output==1) //conditional statements for the toggle procedure
clock_output=0;//clock =0
else
clock_output=1;//clock = 1
buzzer=!buzzer;// toggle buzzer just to check
TF0=0;
TL0=0XFB;//count for 100 khz which is given as clock to adc
TH0=0XFF;//count
TR0=1;
//ADC conversion function
unsigned char ADC_conversion()
unsigned char converted_data=0; //variable to store the A-to-D converted data
ADDA=0;
ADDB=0;
ADDC=0;
mydelay(2);
//data_bus=ADC_ch_no; //sending the address to the Port 1 to select the appropriate channel
address_latch=1; //low to high transition to the ALE pin of ADC0808 to latch the address
mydelay(2);
start_conv=1;
mydelay(2);
address_latch=0;
start_conv=0;
while(end_conv==1);
while(end_conv==0);
output_enable=1; //low to high transition on the OE pin to enable the output(to enable extraction of the converted data from the ADC)
//data_bus=0xFF; //declaring the Port1 as input port
mydelay(2);
converted_data=data_bus; //storing the data converted into the variable
output_enable=0; //reset the OE pin
//start_conv=0; //reset the SC pin
return converted_data; //return the converted value
void adc_init()
ADDA=0;
ADDB=0;
ADDC=0;
start_conv=0;
output_enable=0;
clock_output=0;
address_latch=0;
end_conv=1;
data_bus=0XFF;
void timer_init()
TMOD=0X01;
TL0=0XFB;
TH0=0XFF;
IEN0=0X82;
TR0=1;
//Main function
void main()
buzzer=0;
lcd_init();
timer_init();
adc_init();
//infinite loop for constant polling the ADC channel for analog values to be captured and converted
while(1)
val=(ADC_conversion()); //passing the converted value to port 2
sprintf(buffer,"%u",val);
lcd_commandsend(0x06);
DELAY(5);
lcd_write(buffer);
DELAY(5);
//lcd_commandsend(0x01);
//and the negation(~) is done considering
//the LED connections on the controller board
} //end of the while loop
} //end of the main function
