Hello,
I need help with my project. It´s about A-scan ultrasound, used for eye biometry(more here:
http://emedicine.medscape.com/article/1228447-overview). It will serve as a learning tool at my school.
I want to get signal from ADC to PC:
ADC -> buffer -> ATXmega -> USB -> PC
or
ADC -> parallel-to-USB converter -> PC
FPGAs are commonly used in ultrasound devices, but I want to avoid them, because I have no experience with them.
Specifications:
-one data channel
-trandsucer resonence frequency - 2,25 Mhz
-8 bit external ADC atleast 22,5 MSPS
-powering, data and commands via USB
-only data bursts - not continuous data flow:
-ultrasound velocity in water = 1540 m/s = 1.54 mm / us
-eye ball diameter doubled = 50 mm
-one measuring will take 50/1.54 = 32.5 us
-> 22,5 sample on 1 us -> 32.5*22,5*8 = 5850 bits from one measuring
-> 730 bytes per one measurent
I found ADC08B200 from TI, it suits my needs with 8bit, sampling rate, 1kB buffer...
Questions:
Do you know about ADC with bigger buffer memory?
Do you know about any parallel-to-USB converter? Maybe with FTDI chip (didn´t find any that suits my requirements).
I have found few boards like this (
**broken link removed**) but it is overkill for my project.
