Apr 7, 2006 #1 N nijMcnij Full Member level 1 Joined Dec 6, 2005 Messages 97 Helped 5 Reputation 10 Reaction score 4 Trophy points 1,288 Activity points 2,167 ADC simulation testing hello all, i am designing an ADC, and i was told that there is a way to create a verilog model for a block which can be connected to the ADC digital outputs. the verilog block can then write the digital codes from the ADC to a file. how can i do this many thanks
Apr 8, 2006 #2 W willyboy19 Full Member level 3 Joined Feb 15, 2004 Messages 152 Helped 12 Reputation 24 Reaction score 2 Trophy points 1,298 Activity points 1,705 Re: ADC simulation testing Try use $fstrobe function and it will do the job.
Apr 8, 2006 #3 S swicap Member level 5 Joined Apr 4, 2004 Messages 86 Helped 14 Reputation 28 Reaction score 3 Trophy points 1,288 Activity points 637 ADC simulation testing VerilogA model can do that, it is easy to write this va block, check veriloga reference.
Apr 10, 2006 #4 N nijMcnij Full Member level 1 Joined Dec 6, 2005 Messages 97 Helped 5 Reputation 10 Reaction score 4 Trophy points 1,288 Activity points 2,167 Re: ADC simulation testing i have created a verilog A model that uses the $fstrobe function. hwoever the outputs of the ADC are 3.3V for a digital 1 and 0 for a digital 0....how can i use $fstrobe inorder to save a 1 for every 3.3V on the digital outputs. many thanks
Apr 11, 2006 #5 S swicap Member level 5 Joined Apr 4, 2004 Messages 86 Helped 14 Reputation 28 Reaction score 3 Trophy points 1,288 Activity points 637 ADC simulation testing $fstrobe can export data to a file. use matlab to analysize the data. It will be very easy to solve the problem u met.
Apr 11, 2006 #6 R redswat Newbie level 6 Joined Dec 20, 2002 Messages 13 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 66 ADC simulation testing maybe you can use a ideal DAC in analog netlist to test your ADC outputs
Apr 12, 2006 #7 C chenliy Junior Member level 2 Joined Mar 9, 2005 Messages 20 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,283 Activity points 1,608 Re: ADC simulation testing You could connect the input of DAC with the output of ADC.
