djc
Advanced Member level 1
- Joined
- Jan 27, 2013
- Messages
- 402
- Helped
- 3
- Reputation
- 6
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- India
- Activity points
- 4,554
Here is the code for ADC using 16f72.
1) RA3 is selected as input channel
2) Knob is connected to RA3 pin on kit, by varying it we can have ADC result which is displayed on PORTB.
3) GO/DONE bit must be set before monitoring it for going low.
void main() {
unsigned int temp,i;
//TRISA = 0xff; //Set port A direction as i/p
TRISA = 0x00; //Port A as output
PORTA = 0X00; //ALL BITS OFF
ADCON0 = 0X18; //CLOCK SELECTION AND ANALOG CHANNEL SELECTION channel RA3 as input
TRISB = 0x00; //Set port B as output
TRISC = 0x00;
ADCON1 = 0X01; //ALL CHANNELS AS ANALOG INPUT Vref is RA3
//ADCON1 = 0x00; //Vref is VDD
TRISA3_bit = 0; //Port A 0th bit as input
TRISA2_bit = 0;
TRISA1_bit = 1;
TRISA0_bit = 1;
PORTB = 0xFF;
Delay_ms(1000);
PORTB = 0x00;
Delay_ms(1000);
PORTC = 0x00;
while(1)
ADRES = 0x00;
ADCON0.ADON = 0x01; //Turn on the ADC
ADCON0.GO = 1;
//ADCON0 = ADCON0 & 0x04;
//while((ADCON0 & 0x04)==1); // Wait till conversion is going on
while (ADCON0 == 0x04);
//while(ADCON0.GO == 1);
ADCON0 = 0x00; // Stop the ADC
// ADIF = 0;
//temp = ADRES;
PORTB = ADRES;
//PORTA = ADRES;
//PORTC = ADRES;
Delay_us(2); //Call delay 2 microseconds;
