ADC DAC Required...
Can you propose any ADC with the below spec.
1) Sigma Delta
2) More than or equal to 14bit resolution
3) Should be a single bit output without any internal memory reading.
4) Sampling rate more than 30MHz.
5) Supply Voltage Range Max 5V, Min 1.8V
6) INL, DNL and other parameters does matter.
Similarly any DAC with the below spec.
1) Minimum 12bit parallel output.
2) Analog Input range Max 3.3V
3) Sampling rate more than 30MHz.
4) INL, DNL and other parameters does matter.
5) It should be a simple converter without any programming.
Appreciate your help in advance….
Thanks
Anish
