mtech84
hello all this is the code below i am getting error
Error (10405): VHDL error at CONTROLLER.vhd(68): can't determine type of object at or near identifier "to_bitvector" -- found 0 possible type
help me to remove the error to_bitvector what shall i use i tried just bit does not work..
code:===============================
LIBRARY IEEE; USE IEEE.std_logic_1164.ALL;
USE STD.textio.ALL;
-- ENTITY DECLARATION
ENTITY CONTROLLER IS
GENERIC (
CONSTANT sWait : integer := 0;
CONSTANT sSample : integer := 1;
CONSTANT sConv : integer := 2;
CONSTANT sDone : integer := 3);
PORT ( CLK : IN bit; --clock input
go: IN bit; -- go =1 to perform conversion
valid : OUT bit; -- valid = 1 when conversion finished
result: OUT bit_vector(7 downto 0); --8 bit result
sample: OUT bit; -- to s & H circuit
valu: OUT bit_vector(0 downto 0); -- to dac
cmp:IN bit); -- from comparator
--LEDG : OUT STD_LOGIC_VECTOR(8 DOWNTO 5);
--HEX0 : OUT STD_LOGIC_VECTOR(0 TO 6)
END CONTROLLER;
ARCHITECTURE CONTROLLER OF CONTROLLER IS
SIGNAL state : bit_vector(1 DOWNTO 0); --currently state in state machine
SIGNAL mask : bit_vector(7 DOWNTO 0); --bit to text in binary search
-- Intermediate signal for valid
SIGNAL valid_xhdl1 : bit;
-- Intermediate signal for result
SIGNAL result_xhdl2 : bit_vector(7 DOWNTO 0);
-- Intermediate signal for sample
SIGNAL sample_xhdl3 : bit;
-- Intermediate signal for value
SIGNAL value_xhdl4 : bit_vector(7 DOWNTO 0);
---state assignment
--CONSTANT sWait : integer := 0;
--CONSTANT sSample : integer := 0;
--CONSTANT sConv : integer := 0;
--CONSTANT sDone : integer := 0;
BEGIN
valid <= valid_xhdl1;
result <= result_xhdl2;
sample <= sample_xhdl3;
valu <= value_xhdl4;
-- synchronous design
PROCESS
BEGIN
WAIT UNTIL (CLK'EVENT AND CLK = '1');
IF (NOT go ='1') THEN
state <= to_bitvector(sWait,2); --stop and reset if go=0
ELSE
CASE state IS
--choose next state in state machine
WHEN to_bitvector(sWait,2) =>
state <= to_bitvector(sSample,2);
--start new conversion so
state <= to_bitvector(sConv,2); --enter convert state next
mask <= "10000000"; --reset mask to msb only
result_xhdl2 <= "00000000"; -- clear result
WHEN to_bitvector(sConv,2) =>
--set bit if comparator indicates input larger than value currently under consideration, else leave a bit clear
IF (cmp = '1') THEN
result_xhdl2 <= result_xhdl2 OR mask;
END IF;
--shift mask to try next bit next time
mask <= ShiftRight(mask , 1);
--finished once LSB has been done
IF (mask(0) = '1') THEN
state <= to_bitvector(sDone,2);
END IF;
WHEN to_bitvector(sDONE,2) =>
WHEN OTHERS =>
NULL;
END CASE;
END IF;
END PROCESS;
sample_xhdl3 <= to_bit(state = to_bitvector(sSample,2));
value_xhdl4 <= result_xhdl2 OR mask;
valid_xhdl1 <= to_bit(state = to_bitvector(sDone,2));
END CONTROLLER;
Added after 52 minutes:
plz reply...... thx.....
USE STD.textio.ALL;
GENERIC (
END CONTROLLER;
---state assignment
BEGIN
PROCESS
BEGIN
ELSE
CASE state IS
IF (cmp = '1') THEN
END IF;
END IF;
WHEN OTHERS =>
NULL;
END CASE;
END IF;
END PROCESS;
END CONTROLLER;
