nikhil_jain
Member level 4
Hi
I'm trying to work with ADC for the ARM controller on the new Arduino Due board, but no success so far. Has anyone done this already?
This is my code:
I'm using Atmel Software Framework (ASF) in Atmel Studio.
Thanks
This is my code:
void ADC_IrqHandler(void);
void adc_setup(void);
#define PIOC_Set_Output *((uint32_t volatile *)0x400E1230) //PIO_SODR
#include <asf.h>
//ADC Interrupt handler
// Check the ADC conversion status
if ((adc_get_status(ADC) & ADC_ISR_DRDY) == ADC_ISR_DRDY)
uint32_t result = adc_get_latest_value(ADC);
PIOC_Set_Output = result;
adc_init(ADC, sysclk_get_main_hz(), sysclk_get_main_hz()/4, 8); //ADC_CLOCK = master_clock/4
adc_configure_timing(ADC, 0, ADC_SETTLING_TIME_3, 1);
adc_set_resolution(ADC, ADC_MR_LOWRES_BITS_12);
adc_enable_channel(ADC, ADC_CHANNEL_5);
adc_enable_interrupt(ADC, ADC_IER_DRDY);
adc_configure_trigger(ADC, ADC_TRIG_SW, 0);
int main (void)
board_init();
sysclk_init();
adc_setup();
volatile uint8_t count = 0;
while(1)
adc_start(ADC);
count++;
Thanks
