I am currently trying to simulate Block RLS for SC- MIMO using STBC. I am attaching the paper. While Reading the paper I found the it was mentioned that in Value of δ used in Block RLS is very large. But in normal RlS the value of δ is usually very small around 0.1 or 0.01. Could any body tell me the approximate value of δ used in Block based RLS.
Also In Block based NLMS what is the approximate value of µ and ε. In normal NLMS generally ε is a very small value and 0 ≤ µ ≤ 2. Does this condition hold for block based NLMS too.
Hi ,
I have simulated MIMO CHANNEL Estimation for MIMO USING Block based NLMS Algorithm. SPACE time block coding is used. I am attaching the matlab code. Please analyse and post your comments. If you have identified anything please write back.
