AD595 fail ( Thermocouple IC )
Sajjadkhan
Full Member level 5
Rawalpindi,Pakistan
i havent found any article about my new problem that i found with AD595. i was attempting to make a soldering station and it was a success but sometime values flickered alot, not that often that is. then later i found that this "not that often" time gap is when i use to receive my sms or call or dial a call using my GSM based phone.
1st i thought it was the thermocouple leads which are of a meter long or my analog and digital grounding separation is not that effective. so i made a prototype on the bread board as standalone Celsius meter i.e. no pic attached to it. even then there are pulses going upto Vcc rail of Ad595. As i m using this ic as a standalone Celsius meter so there is no thermocouple attached to it rather a 1 inch jumper wire from pin 14 goes to pin 1 and pin 1 is effectively grounded(without any resistor). then i made a pcb just for ad595 like brakeout board and shorted pin1 and 14 directly under the pcb, noise was dramatically removed but still 0.5v noise remained.
Conclusion: using any sort of filter on pin 1 and 14 is of no use because op-amp on pin 1 and 14 has very high impedance,more than needed so it creates and effective antenna with a small piece of wire. so if you want to use it properly then you may have to shield your box and ground that shield, which i dindnt try yet, nor i m willing to. i will perform same experiment with max6675 and max31855 and will post the results.
My conclusion is quite different. Thermocouples are low impedance sensors, thus thermocouple amplifier inputs can be easily and effectively filtered.
General comment. A popular fault with AD595 and similar differential amplifiers is to forgot the required ground/bias connection for the sensor. RF interfernces shouldn't be an issue. A solid circuit ground, e.g. PCB ground plane and sufficient bypass capacitors may be required however.
See AD595 datasheet:
Common-mode voltages on the thermocouple inputs must remain within the common-mode range of the AD594/AD595, with a return path provided for the bias currents. If the thermocouple is not remotely grounded, then the dotted line connections in Figures 1 and 2 are recommended.
AD595 datasheet 1st page: look into features: High Impedance Differential Input.
I have done what you are saying and whats in datasheet, as i said pin 1 and 14 are grounded and connected together. with thermocouple i always prefer to remotely ground it at the tip.
i also applied filter as in the application notes of AD595 but problem remains, since its in the pins. Have you tired Ad595 as in my conditions?
I am talking about op-amp impedance not the thermocouple impedance.
I know, but it doesn't necessarily involve a high interference succeptibility. The applicable filter impedance is commanded by the sensor impedance.
I believe that the RF interference sensitivity is caused by your grounding and supply bypass scheme.
I'm somewhat sceptic about noise level measurement numbers without a bandwidth specification. My performance criterion would be the stability of DC output value, e.g. measured with a multimeter with a preceeded a low-pass.
Put a 0.1 uF capacitor between pin#1 and pin#14 and a 330 ohm resistor on pin#1 in series with thermocouple.
Pin#14 is grounded.
