action of voltage drop..
Bhuvanesh Nick
Member level 1
Member level 1
in the above circuit.what are all the voltage drop that i getting is given to led..am i right or wrong.if wrong is there any action realted to voltage drop of resistor to led clarify me plzz
Depends from power source and from R1 value.
If you use small battery and R1 have low value this can cause voltage drop.
For example full car battery have voltage 12,72V-12,73V when cranking (apply load) voltage fall down to around 10-10,5V.
Best regards,
Peter
Best regards,
Peter
Sir if i have 1.5v supply one variable resistor and led..can i make it to glow even the requirement of led id 3v
