accident detection, lp
kshitij_lakhani
Newbie level 5
Newbie level 5
this is in relation to the following post
https://www.edaboard.com/threads/244902/
im really stuck at this point since last two days. The point being the microcontroller detects accident when accelerometer is given a jerk, but isnt sending any msg nor it displays msg sent on LCD where as led D1 turns on inspite of that. I checked the code many times and im not able to figure out the reason behind it , leaving me thinking that somethings wrong to connections i have made.hence im sending you the image of the connections made by me while i am testing the project completely assembled . please please look into it once and confirm the connections made are correct or not. i need it badly and it ill be really great if you could help me out once again. the images are posted along.
Also , id like to mention that i have checked the gps and gsm modules independently on hyperterminal and they work perfectly fine . Also , i have used the same development board from nex and accelerometer too, from nex ; and i am using codes mentioned in the above thread itself.
Please do reply asap. I would be really grateful. Thanks !!!
Reply With Quote Reply to Private Message Forward Message Forward View Profile Private Message
Quick Reply
