Accessing a c variable in modelsim
rayan123
Newbie level 5
Newbie level 5
I am using modelsim to simulate a DPI files and want to access a variable from a c file. I am not sure if i can do that. I tried to find the command for this but could not. Is it possible, if so what is the command.
Thanks in advance
If you mean you want to access a Verilog/SystemVerilog variable from a C file, you cannot do it directly. You can either export a SV function that returns the value of the variable you want to access(preferred), or you can write VPI routines to access the variable.
After reading the title of your post again, it seems you want to access a C variable from Modelsim. You can do this with the properly licensed version of Modelsim/Questa that supports C debug. See the C debug section of the User Manual.
Or maybe you meant you want to access a C variable from SystemVerilog. You can't do that directly either. You would have to import a C method that does the access for you.
Hi Dave,
Thanks for the reply.
What i meant was, is it possible to add c variables from system verilog into questasim wave, so that i can see how that c variable is changing its value at different clock edges
Regards,
Rayan
You can't do that. Your C code is compiled by a generic C compiler and does not produce "update" events when someone writes to a variable. As I said, you would need to either call a C DPI function that polls the C variable at each clock cycle, or export a SV function that sets an SV variable that you can add to the wave window. There might be other ways depending on how your DPI code executes.
