ac voltage regulation
zohaib
Member level 4
PAKISTAN
hello everyone
in a battery charging circuit how can i regulate ac mains through triac
you can use variac (variable transformer)
or transformer with multi turns with relays..
and switching ckt..
    zohaib
voltage regulation = (no load voltage - full load voltage) / full load voltage
    zohaib
in the above diagram by varying the pulse width you can change the output power.... you just have to filter it to get the output you need....
    zohaib
yes thats the good one
    zohaib
