hi
basically i want to make Centrifuge Machine for my FYP, for this i want a circuit diagram , source code of this Keil Uvision software,
i have to control the AC motor's RPM, also a timer which is set in between 1 to 25 minutes , a beep after the timer is off/stoped , stop option , reset option(for timer) , during motor is Spinning the door will remain closed(it could be done by solonoid switch/mechanism ,but its coding and timing should be include in program/source code), also a message display on LCd that COMPLETE with a beep,
please do let me help in this its not a big deal simple project but i am weak in programing 8951 also have no idea of using any king of ADC.
