LEM has a similar idea, but requires special attention to the PCB since the current does not pass through the IC (as it does in the Allegro case)
Browse their web site, they may have something close to what you need.
Of course you can also simply sense across a resistor- it depends if you need isolation
You can use bolometry -- run the AC current through a resistive load, then measure the temperature. This is done in some older high-end RMS Voltmeters... Jim Williams has some literature on the topic. Search LTC's appnotes.
1. Hall-effect current sensors.
2. Resistive (voltage drop across ressitor) current sensors.
This application note discusses these 2 methods: **broken link removed**
You can also post your message to this group: **broken link removed**
