chxgzl4862
Member level 1
warning:ngdbuild:452
hi everybody
my project
entity CLKDIV is
port (
CLK_IN : in std_logic;
CLK_RST: in std_logic;
CLK_CS : in std_logic;
CLK_NUM: in std_logic_vector ( 8 downto 0 );
CLK_OUT: out std_logic
end CLKDIV;
architecture Behavioral of CLKDIV is
signal CLK_CLK: std_logic;
signal CLK_CNT: std_logic_vector ( 8 downto 0 );
begin
div: process ( CLK_RST,CLK_IN,CLK_CS )
begin
if ( CLK_RST = '0' ) then
CLK_CLK <= '1';
CLK_CNT <= "000000000";
elsif ( CLK_IN' event and CLK_IN = '1' and CLK_CS = '0' ) then
CLK_CNT <= CLK_CNT + 1;
if ( CLK_CNT = CLK_NUM ) then
CLK_CLK <= not CLK_CLK;
end if;
end if;
end process div;
CLK_OUT <= CLK_CLK;
end Behavioral;
entity IIC_CLK is
port (
IIC_CLKIN: in std_logic;
IIC_RST: in std_logic;
IIC_CS: in std_logic;
IIC_CLKOUT0: out std_logic;
IIC_CLKOUT1: out std_logic
end IIC_CLK;
architecture Behavioral of IIC_CLK is
component CLKDIV
port (
end component;
signal IICaaaaSampClk: std_logic;
signal IICaaaaClk: std_logic;
signal IICDivNum0: std_logic_vector ( 8 downto 0 );
signal IICDivNum1: std_logic_vector ( 8 downto 0 );
begin
IICDivNum0 <= "000000000";
IICDivNum1 <= "000000000";
IIC_CLKOUT0 <= IICaaaaSampClk;
IIC_CLKOUT1 <= IICaaaaClk;
I2C_SampClk: CLKDIV
port map (
CLK_IN => IIC_CLKIN,
CLK_RST => IIC_RST,
CLK_CS => IIC_CS,
CLK_NUM => IICDivNum0,
CLK_OUT => IICaaaaSampClk
IIC_Clk: CLKDIV
port map (
CLK_RST => IIC_RST,
CLK_CS => IIC_CS,
CLK_NUM => IICDivNum1,
CLK_OUT => IICaaaaClk
end Behavioral;
WARNING:Xst:1989 - Unit <IIC_CLK>: instances <I2C_SampClk>, <IIC_Clk> of unit <CLKDIV> are equivalent, second instance is removed
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<0>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<1>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<2>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<3>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<4>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<5>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<6>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<7>' has no driver
WARNING:NgdBuild:452 - logical net 'I2C_SampClk/CLK_NUM<8>' has no driver
why? ise 10.1 xinlinx xc95144
hi everybody
my project
entity CLKDIV is
port (
end CLKDIV;
begin
begin
CLK_CLK <= '1';
end if;
end if;
end process div;
CLK_OUT <= CLK_CLK;
end Behavioral;
entity IIC_CLK is
port (
end IIC_CLK;
component CLKDIV
port (
end component;
begin
I2C_SampClk: CLKDIV
port map (
CLK_RST => IIC_RST,
CLK_CS => IIC_CS,
IIC_Clk: CLKDIV
port map (
CLK_RST => IIC_RST,
CLK_CS => IIC_CS,
end Behavioral;
