In Star RCXT, for XREF, there are three options: NO, yes, complete. For my design, when i set XREF to yes, cell_type to layout and net_type to schematic, i extracted two netlists from layout: ideal netlist, and spf netlist, and, the ideal netlist and the spf netlist both have correct
connection, the same as cdl pre-layout netlist, so, the XA back-annotation is 100%. But when i set XREF to complete, set cell_type to schematic, and set net_type to schematic, the extracted ideal netlist still has correct connection (same as cdl pre-layout netlist), while the extracted spf netlist have some wrong connections relative to the cdl pre-layout netlist.
for example, there are two MOS transistors in cdl pre-layout netlist,
MM1 net1 net2 net3 net4 PM L=1u W=2u
MM2 net5 net6 net7 net8 PM L=1u W=2u
but in the extracted spf netlist, net5 is connected to SRC of M1, not to DRN of M2, and there are lots of such wrong connections (for the case of XREF: yes, there is no any wrong connection), and all the wrong connected instance and net are related to SRC and DRN node of MOS transistors,
such as:
*|I X1/XI23/Xi45/XI0/MM1:SRC X1/XI23/Xi45/XI0/MM1 SRC B 0
Does anyone met this problem before?
Please help me, i really need your help, thanks all.
