about IC5141/IC5033 dracula?
mylihua
Junior Member level 2
Dear all,
run in liunx suse10 :
% jxrun.com
CREATED ON 25-NOV-2005 23:36:28 PDRACULA REV 4.9.05-2004 301
0.050u 0.072s 0:00.16 75.0% 0+0k 0+0io 0pf+0w
*/N* DRACLM (REV. 4.9.05-2004 / LINUX /GENDATE: 5-APR/2004 )
*** ( Copyright 1995, Cadence ) ***
*/N* EXEC TIME =23:51:03 DATE =25-NOV-2005 HOSTNAME = lzh.loca
LICENSE REQUIREMENT
DRAC2CORE 4.900000
DRACERC 4.900000
DRAC2LVS 4.900000
Segmentation fault (core dumped)
set Path is Ok. but have above problem!!!
use linux system : suse10 , core ver: 2.6.x .
but , run linux redhat9, core ver: 2.4.X is Ok
I need help!
Thank you.
Back to top
ur dracula license server is different than the one on which u r running dracula. submit ur job on that server.
    mylihua
but, I run in redhat9 is Ok!!
thank yout!
Use : export LD_ASSUME_KERNEL="2.4.1" in your bashrc file .
I've also set ASSUME_KERNEL=2.4.1 .
I find its the draclm problem.
I have the same situation as you (CentOS4.3 , IC5141),
after install a update it will be ok.
rabit: what update have you installed? I use CentOS4.4 and IC5141, when I run dracula, there is a core dump error, just like mylihua said.
I install usr1 for IC5141.
