Most i/o of digital circuits contain some kind of ESD protection circuit, which frequently consists of clamp diodes shorting the ESD zaps to Vcc or Gnd and limits the maximum i/o voltage of these devices to Vcc + (1 diode voltage drop).
1-I know this will be a silly question but, if applying a voltage higher than Vcc+0.3 can damage pins containing these diodes, how could these diodes protect the i/o from hundred of volts that can be generated by ESD?
2-If an input doesn't contain an ESD protection circuit, what is the thing that limits the maximum voltage that can be safely applied to the input without using any other passive element?
3-Is it safe to apply any voltage to any pin as long as the current through that pin is limited by passive elements below the maximum rating of the devices? Or should voltage and current independently considered?
Thank you in advance...
