about frequency plan tools
mydreamhouse
what is the best software for transceiver frequency plan?
Ypu could look at ansoft designer - student version which is free to download. This has a system simulator and should be able to do some of the basic transceiver system calculations.
Shogun
Hi all,
Just for my understanding.
What is frequency planning.
case 1: In trasceiver means, what should be the LO frequency if IF is this and RF is this , predict where the spurious will fall and find a suitable frequency for TX and Rx.
and case 2. in Cell. (mobile , BS application) Frequency of each cell w.r.t adjacent cell, spacing, reuse etc
Am I right.
I think mydreamhouse is talking about first case.
Usually I have seen people using Excel sheets for this . is there any readily available software??
shogun -Has ansoft got this option.
Regards
GV
thank you!!
yes,i mean how to determine LO and IF for a new transceiver and how to analysis spurious.
i known some excel sheet can calculate spurious, but it is too easy. ADS may be a choice for RF budget but for spurious analysis.
Check RFcafe.com. Kirk has there good tool for frequency planning. Also Genesys has good planning tool.
u also can use ADS in spurious analysis. but it will take time . frequqncy planing is a time consuming design step
Genesys has what IF tool , it easily determine the IF frequency
also check some books , u can study the spurious response by some simple hand calculation
khouly
thank you all..........
which software is used in RF planning?
can any one have idea?
plz..........
Goto Top
Is your question same
