A text editor porting on microcontroller
ss_shrenik
Hi Guys,
I wanted to port a text editor on ARM microcontroller (it could be LPC2148 or Stellaris one not decided yet, will decide based on memory requirements). I found leafpad text editor which is a light editor and its source code is available and i am thinking to port that on ARM (http://tarot.freeshell.org/leafpad/). Please let me know if any suggestion or someone have tried to port text editor share guidelines if any.
A Nokia Display. prob 3310 display.
Well for starters, select a larger display! :lol:
I'd rather have a sharp stick inserted under a fingernail, rather than attempt to edit text on a Nokia 3310.
Since you are utilizing a microcontroller with real horsepower, why not incorporate a larger display like a monochrome 128x64 or 160x128?
The KS0108B chipset is fairly straight forward to interface and code.
BigDog
I could not agree more with BigDog. If you are staying with the 3310, then I would look for FIELD editting code - like BOSS [C code modules for field editting]
I am selecting nokia display to reduce cost, as its cost only around 70-80rs. I want to make the device cheaper.
I would look for FIELD editing code - like BOSS [C code modules for field editing]
