a substitute for a 5V relay
Mohammad_Pirzadi
Khorramabad, Iran
Hi dears.
I have a comparator circuit which switches a 5V relay ON or OFF. when the output of comparator saturates toward the positive supply rail,+5V, the relay will go ON; inversly, when the output of comparator saturates toward the negative supply rail, 0V, the relay will be OFF.
the NO contacts of the relay used to turn a 220VAC-60W lightbulb ON or OFF.
Which element could be substitute for the relay?
well perhaps you could perform a web search and learn a little in the process ... ?
Search for an AC SSR (solid state relay) rated for 220Vac and at least 1/2A.
That would be the simplest replacement for a mechanical relay.
