Re: A software to Generate Minkowski curve & simulate in
If you are not doing optimization, the best way to generate such a structure is to use the .3DT format documented in the Appendix. You can use Excel, Mathlab or whatever software to create the pattern of shapes and import it thru .3DT format. It is very simple.
If you want to define the size as optim variable, then you will need to use IE3DLIBRARY to parameterize the structure. It may take some time to parameterize it. However, after the parameterization, you can change the dimensions easily without redrawing it.
