When I setup the HFSS parametric study for one parameters, it seems the variable that defined in "field calculator" can not be display according to it. Is it the limitation of HFSS?
for example, when I change the plane wave polarization to a metal strip, and want to get the induce current on the strip calcuated by integral of H field around strip. The single runs is OK. But once I set up the parametric studies to change incident wave E field direction, there is the problem that I cannot get the Current vs. E direction in the "results".
Any information will be welcome, thanks.
