A simple question about dB calculation.
theasus
Member level 3
Member level 3
I have read definiton of desibel at Wikipedia. But I couldn't understand one point.
When a signal attenuate 3db , how to power of signal change?
Really?
Paragraph 3 of that Wikipedia article answers your question.
So does the table at the top of the page.
"A change in power ratio by a factor of two is approximately a 3 dB change."
I put this in formula but I didn't understand.
3dB increase gives double the power.
3dB decrease gives half the power.
The decibel is a dimensionless number that can express the ratio between two power levels. If we have, for instance P1 and P2
Power ratio(dB)=10*Log(P2/P1)
if the power P2 is the double of the power P1, that is P2=2*P1, then:
Power ratio(dB)=10*Log(2*P1/P1)=10*Log(2)≈3 dB
It works also using absolute dB unit (that means number that have dimension of power), such dBW, dBm and so on.
For instance dBm is the power referred to 1mW:
P(dBm)=10*Log[P(W)/1mW)
if we have, like before P2=2*P1, then the difference between the two levels, in dB will be:
Power ratio(dB)=10*Log[P2/1mW)-10*Log[P2/1mW)=10*Log[2*P1/1mW)-10*Log[P2/1mW)
using the Log properties:
Power ratio(dB)=10*[Log(2)+Log(P1)-Log(1mW)-Log(P1)+Log(1mW)]=10*Log(2)≈3 dB
3 dB is 3 dB. No matter for what - powers or magnitudes relationship. For power this just means 2 times, for magnitude this means sqrt(2) times.
But the thread starter just did not apply his mind to resolve it by himself, I think.
