In the adc papers, I often see the words like "the input range is 1.5Vpp".
But what does it exactly mean? (For example: 1)the single supply voltage is 3v
2)the double supply voltage are
-1.5v、1.5v)
it means peak to peak . if you use oscillograph to do test .and you want to get a pulse, you can see this parameter.
-1.5v、1.5v)
Do you mean that vpp has nothing to do with the supply voltage??
And if we set the input range to be 2vpp, then it only means a range and can't get the exact max and min voltage value??
