A question about the CMOS layout
walkingsun
Member level 2
CN
How long do we need the p-type(on sub) or n-type(on n-well)?
5um?
10um?
20um?
And under what kind of situation?
3ks
protonixs
Full Member level 3
PH
5um?
10um?
20um?
3ks
hello!
i dont really get your point.
renwl
Advanced Member level 1
shanghai,china
yes,it's very confused.
can you give some detailed explanation?
raduga_in
Full Member level 4
India's Silicon Vally
Hi walkingsun,
All these questions are genarally based on the DRC rules
defined by a particular foundry .. please specify the foundry
technology and the sub-block for which you are asking this
question.
walkingsun
Member level 2
CN
i mean how many micron the distance of p-type could be away from another p-type?
the distance is longer, the grounding is weaker, but the area is smaller
renwl
shanghai,china
the ground is not connected by p-sub only.
there are many contacts to metal layers. so the grounding is not too much weak.
mujju433
Full Member level 3
Hello boss we are not able to understand ur question plz be clear
The answer is it depends upon the design rules which we get by the foundry and those are minimum width,minimum distance between poly to poly and so on... these are the design rules.It doesn't mean that u shud always use meet the design rules i mean there may be a situation that u will not be able to go with a design rules so at that time u can keep 0.08 if the design rule is 0.07
I hope it is clear now
Bye take care
