I have designed a 2nd order delta sigma modulator. In TT 25 corner the SNR is 63.8 dB. The worst result is obtained in the SF 85 which has 33 dB SNR. I want to improve the modulator performance so that it reaches a minimum SNR of 62 dB in all corners.
Is it possible to do this by improving the opamps, that is increasing their gain or bandwidth, or should I do something else?
Any suggestion.
could u plz explain more on the architecture u have used. is it SC or CT?, no. of quantizer bits?. is this a post layout simulation? are u considering parasitics also while simulating? wat process and supply voltage u r working on?wat kind of dac are u using in the feedback?plz explain in detail bout it, then someone shud be able to help u out..
Thanks for your reply.
The details are so:
SC architecture, 1 bit quantizer, No parasitics are considered, process is 0.18 um and the supply voltage is 0.9 V.
Thanks for your suggestions.
The details are so:
In this case, you better check if your ota can work under the corners you mention with this supply voltage. Also, check your on switch resistance under this low voltage requirement.
I would also check the leakage current under this supply voltage (the reverse bias pn junction is now 0.9V)
