bhl777
Full Member level 6
Hi all, when I was reading Hans Camenzind's book (http://www.designinganalogchips.com/_count/designinganalogchips.pdf), I have a question about compensation capacitor in the opamp, could anyone take a look of the following question?
In the last paragraph of page 6-12, the author wrote:"It is also important that the capacitor feed back the AC signal from a reasonably low impedance (here the output) to a very high one (the current mirror and the base of Q4) so that we get nearly the full AC voltage swing at this point."
I did not quite understand the last two words "this point",
(1)which point he was mentioning? The low impedance node or the high impedance node?
(2) Could anyone explain why this compensation capacitor has the effect on AC swing?
Thank you!
Thank you!
